Components in a Ford Focus
Username: Malby7
Post Number: 54
Well I have a Focus hatch and I was thinking of getting a pair of JBL 608GTi 6.5" Components. Right now I have 4 Infinity 6"x8" Coaxials running off of a JL Audio 300/4 (75 watts RMS per channel). Now I've heard guys say that having rear speakers is actually worse so they recommend having fronts and a sub. My options are:
1) Keep what I have.
2) Get the components up front and keep the 6"x8" in the back.
3) Put just the components up front and swith my amp to 2 channel.
What do you guys recommend I do?
Username: Maxkilla
Malta
Post Number: 71
Use components for fronts and a subwoofer for back... If you want a rear fill buy a set of mid-basses .... Clarity and sounstage will be best with this system...
Username: Malby7
Post Number: 58
So ur saying option number 3 right? And if I want I can just switch it back to 4 channel if I want the rear speakers again?
Username: Malby7
Post Number: 61
bump
