Looking for Cabasse radio code (Grand Scenic 2005)
Username: Boombo
Hi,
like others newbies, i've put a new battery without verifying i had the radio car code...
is someone can help me ?
It's the cabasse 6CD system
The number is :
8 200 300 863 --A
PN
MH9RN01W
04 52
BAR CODE:
8200300863TJ564
Thanks
Username: Regrooster
Post Number: 8046
try code 6931...but this may not work as I think it is a radio made by Alpine
Please post back here if successful or not
Username: Boombo
Thanks for your answer but it doesn't work...
Do you think there is another solution ?
Post Number: 8048
No , I don't think so..or at least not for free from anywhere on the Internet.
Unfortunately the normal Renault Security Code Calculator doesn't seem to work on these Renault radios made by Alpine.
You will have to try your Main Renault Dealer or a Radio Decoding Service.
(sometimes Renault dealers will give you your code for free if you have all the paperwork)
If you do get a working code, can you let me know what it as this information may be useful in the future.
Username: Boombo
Thanks a lot for your time.
On monday, I'll go to the Renault Local Dealer, trying to get the code (for free I hope so).
I'll let you know it. Perhaps it will help someone to make a code generator.
Post Number: 8050
One final comment.
If you have any official Renault Dealer receipts amongst your paperwork (for servicing or repairs etc) then often the radio code is listed amongst the details.
Worth looking?
Username: Boombo
It's a used car i've bought. I have a lot of papers but i've not found the code.
But you're right, it's worth have another look !
