Renault Megane radio code help needed
Username: Dazz
Hi can anyone help with code for a Renault Megane x-reg
Radio Model 22DC259/62T
TOH626
RN259FY0143406
PRO No; FD0200240143406
7700434422TH626
7700 434 422
all the info on radio is listed above, thank you for your time.
Username: Hay88
PortsmouthUk
Post Number: 3707
Dazz
code 3141
You must hold at the end to store your code.
IF YOU DONT HAVE ¬ KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A¬} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
Username: Dazz
Thank you very much
A very fast answer and it worked easily, thank you hay88.
I have many hundreds of miles to drive the next week now with some music.
Thanks again
Username: Rita11
H i can you please help me find radio code for Renault Megane,
details on the back of radio are
Code Gravage 4056793
Renault Radiosat 6010
7700 433 072
Philips22DC461/62L
9022 214 61624
CD changercontrol 7700 433 072 v129
FD 09 98 41 4056793
model no 22DC461/62L
PROD NO FD 0998414056793
7700 433 072 V129
on the side of radio 902221461624
22DC461/62L
M/ch:055053
Would be very grateful if you could sort it for me,travelling from abroad with no radio,Thank you
Username: Hay88
PortsmouthUk
Post Number: 3713
Rita11
code 4808
please look back up two post on how to enter
Username: Ipom
Hi,
Could you help me with this one, please?
Renault Tuner List
Model: 22DC279/62Z
Prod No: FD0100510018817
Serial: 820002607TE670
Username: Regrooster
Post Number: 8040
Ipom
Username: Ipom
Ipom posted on Friday, August 05, 2011 - 14:30 GMT
Hi,
Renault Tuner List
Model: 22DC279/62Z
Reminder :..NO MULTIPLE CODE REQUESTS ON THIS FORUM
Single free code request for personal use only (one code request every 6 months minimum)
This is to prevent abuse by traders+dealers, car radio thieves and other chancers
Sorry if you are one of the honest ones !
Username: Rita11
Thank you very much,it worked.Much obliged
