Code radio PU 2294A ©
Username: Frkmr
have "7error" on display
PU 2294A ©
s/n CL040150996395C
thank
Username: Regrooster
Post Number: 8082
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
Username: Frkmr
thank you
