I need a radio code please
Username: Pavlikfil
Renault scenic 2001
model 22DC259/62p
prod FD0501080232122
tov596
RN259f10232122
thanks in advance ...!!!
Username: Hay88
PortsmouthUk
Post Number: 3683
Pavlikfil
code 4477
You must hold at the end to store your code.
IF YOU DONT HAVE ¬ KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A¬} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
Username: Mladja014
Hello,
Code needed,my wife will cut my figers because I reset car radio
Model no:22DC279/62Z
T0W775
RN279F10031708
Product No:FD0101060031708
Thanks
Username: Hay88
PortsmouthUk
Post Number: 3689
Mladja014
code 3241 please look up one post to see how to enter
Username: Mladja014
I did it, the code is appropriate. You're a genius. Thank you very much. greeting
