Radio code for Laguna 2
Username: Aminuwinch
The radio stopped working when I changed the battery. What details do you require to help me with the radio code?
Thank you.
Username: Regrooster
Post Number: 8157
The radio has to be removed from the dashboard
Then quote the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
