New member Username: Deamod
Post Number: 1 Registered: Jul-11
Posted on 7 648 146 392 BP146x3069666 thanx for your help... |
Gold Member Username: Regrooster
Post Number: 7978 Registered: Aug-08
Posted on try code 4531 |
Post Number: 2 Registered: Jul-11
Posted on no avail. What else can I do? |
Post Number: 7980 Registered: Aug-08
Posted on 4531 has been checked again and is the correct code for the Serial Number quoted Check your numbers again. If correct then your radio may have been recoded to a completely different number |
