Radio scenic code
Username: Nanc
I have a problem i have a renault scenic radio but i dont have de code.
model: 22dc278/62p
rn278f30182434
8200152346te750.
Please can anybody help me
thnx
Nanc
Username: Regrooster
Post Number: 7845
try code 2497
Username: Puutin
Need a code to
Renault Philips
model RENRDW131-10
Z972
RNRD03400210098
prod nr FD0604400210098
thanks
Post Number: 7848
Ari
Username: Puutin
Posted on Friday, July 15, 2011 - 03:16 pm:
Need a code to
Renault Philips
model RENRDW131-10
Z972
RNRD03400210098
try code 0071
Username: Chris39
hi guys
just replaced my battered megane casseste player with cd player and didnt ask for code doh!
MODEL 22DC278/62R
TOO839
RN278F20031779
PRODUCT FD0302510031779
Username: Chris39
sorry...thnx in advance\clipart {talker}
Post Number: 7859
chris39
Username: Chris39
Posted on Saturday, July 16, 2011 - 06:29 am:
hi guys
MODEL 22DC278/62R
TOO839
RN278F20031779
try code 1190
Username: Matrixxxxx
hello having changed the battery, the radio does not work, please send me the code?Upload
Username: Hay88
PortsmouthUk
Post Number: 3620
Matrixxxxx
code 7591
You must hold at the end to store your code.
IF YOU DONT HAVE ¬ KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A¬} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
Username: Niki_630
Post Number: 7
Hello, my radio is coded: (
I guess you can help me
Reno Scenic
model No: 22dc259/62 P
TOS631
RM259F10211536
7700434424tS631
Username: Hay88
PortsmouthUk
Post Number: 3650
Niki_630
code 7391
Username: Beghin
Can anyone out there help.
need code for Renault Scenic 2003
Product Code FD0204070104948
Model No RENRDW 131-10
X619 SECURITY
other numbers.....
8200300858TX619
RNRD 00330045697
THANKYOU
Username: Hay88
PortsmouthUk
Post Number: 3668
Beghin
code 2358
