Is it safe?
Hinsu Ablerato
Say I have 2 Kicker comp vr 15's Dual 2 ohm And a Jbl bp1200.1 Amplifier I hook them up with a Box with 1.77 cubic feet each Will they be safe if i dont turn the volume up all the way? Or will the voice coils fry regardless. Or is there anything I can do to someohow make this work safely? Is there always 1200 watts goin to the speakers regardless of how much the deck volume is put at? And there is no way to limit the amp power some how is there
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4056
box sounds too small for fifteens.
if space is an issue, you could do one sealed box for a single fifteen and mount the subs in an isobaric push-pull setup.
that'd fit both subs into the space a bit larger than it usually takes for one sub.
http://www.caraudiohelp.com/custom_car_audio_boxes/custom_car_audio_boxes.htm
like this:
Hinsu Ablerato
Well the Box is specifically Made for the kicker comp vr 15's... Its on ebay Bigdog Kicker Dual 15 box.. But my main focus is the power the subs are recieving. Also what happens if the box is too small?
Username: Glasswolf
Post Number: 4073
well, if you wired it right each sub gets 600 watts.
it should work just fine.
the small box won't sound that great, but if it's sealed and made for those subs it should be ok.
I take it that volume is net, after driver displacment.
