Anonymous |
Posted on I understand impedance spec of Marantz receivers is 8 ohm while impedance for Monitor Audio speakers is at 6 ohm. Will there be any mis-matching or overdrive? Comments anyone? |
SAL |
Posted on Its OK, Marantz can power 6 Ohms speakers as well. |
elitefan |
Posted on Marantz and Monitor is a perfect combination. If you are considering this match you can't do any better IMO> |
