Need an amp
Username: 2000fordranger
Shreveport, Louisiana United States
Post Number: 176
Alright guys, im looking for an amp to power some sa12's w/ and im not sold on anything. Wouldnt mind an used amp if someone has one to fit the bill. As far as new amps go any deals out right now??? I wanna feel good when i buy something not feel like i just spent so much on an amp and didnt even get a discount.
Username: Kaerfpl
Spencerport, NY USA
Post Number: 1137
Regardless if bought the 2/4 Ohm version, I'd suggest looking into the Audioque AQ1200:
http://www.audioque.com/AQ1200D-Amplifier_p_30.html
If you have the DVC 4 Ohm version, then this amplifier is perfect wired to 2 Ohms in Parallel. You could even still use this amplifier if you bought another SA-12 DVC 4 Ohm and wire it down to 1 Ohm in Parallel.
If you have the DVC 2 Ohm version, you can wire the Subwoofer in Parallel to create a 1 Ohm load. These Subwoofers can take a bit more power than they are rated for, but just make sure to set your Gain and other settings accordingly to prevent any damage.
