Mahoe Unregistered guest | if i have two subs that are rated at 300w rms, do i need an amp at about 300w rms or an amp at about 600w rms since i have two subs? thanks |
Anonymous | You need a 600watt amp and wire it at 2ohms for each sub to push the 300watts. |
Bronze Member Username: Colorblind_2004Post Number: 14 Registered: Jul-04 | Thats the way to go my friend. Kudos. |
Mahoe Unregistered guest | any amp recommendations to hook up two alpine typre r subwoofers (300w rms), 12"-2 ohm dvc. i would prefer going with a mono amp. thanks |
Bronze Member Username: JmloughreyFarmington, CT Post Number: 43 Registered: Jul-04 | mahoe, your gonna have to run your amp at 4 ohms...2 ohm DVC can either be wired to 4 ohm or 1 ohm...i beleive... |
Silver Member Username: JayjLouisiana USA Post Number: 326 Registered: May-04 | No Jeff you are thinking of 4ohm DVC subs. DVC 2ohm subs can be wired for 0.5ohms 2ohms or 8ohms. He said he has 2 subs. Mahoe get a JBL600.1 and wire your subs for a 2ohm load. Heres a diagram to help with wiring. http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/car/subwoofers_wi ring.html?subs=2&impedance=DVC2x2 |
