Help lost stereo code for my renault laguna
Username: Nitrous
Hi can anyone help me ive lost the code for my stereo in my renault laguna the details are:
model number: 22dc279/62
Product number: fd0100280086461
7700433948
Thanks in advance if you can give me the code for it
Username: Regrooster
Post Number: 8009
Sorry.......this is insufficient information
The radio has to be removed from the dashboard
Then post the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also post the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
Username: Nitrous
Hi, the 14 character serial number is: RN279FY0086461
and the security number is TOW103
thanks
Username: Hay88
PortsmouthUk
Post Number: 3705
Nitrous
code 3886
You must hold at the end to store your code.
IF YOU DONT HAVE ¬ KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A¬} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
Username: Ghales
Hi can anyone help me too. The battery went flat on my Laguna and I don't have the code to reset the stereo. The details are:-
model Number: 22dc279/62Z
Product Number: FD101270116111
Serial Number: RN279F10116111
Security Number: TOY664
Other details given:-
207B74
2821079
2607
8200002607TY664
Thanks in advance!
Username: Hay88
PortsmouthUk
Post Number: 3711
Ghales
code 1307
IF YOU DONT HAVE Ã,¬ KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {AÃ,¬} KEY
Press the [ Ã,¬] button then rotate the thumb wheel for the correct first digit
Press the [ Ã,¬] button then rotate the thumb wheel for the correct second digit
Press the [ Ã,¬] button then rotate the thumb wheel for the correct third digit
Press the [ Ã,¬] button then rotate the thumb wheel for the correct fourth digit
press and hold the [ Ã,¬] button for up to 10 seconds to store the code
