Volkswagon 2001 Jetta Wolfsburg Edition
Username: Equinas
Does anybody have the code for this? Thanks!
Username: Equinas
Volkswagen..sorry bad speller.
Username: Regrooster
Post Number: 7860
Sorry....Main V W Dealer or Radio Decoding Service only for this code
It will not be available for free or cheap from anywhere on the Internet
Username: Equinas
Reg Rooster..I just called the former car's owner and I couldn't believe that they actually still had it after several years. It is 1409. Now my problem is that I don't know how to enter it. They did not remember. Do you know what it means when it says "SAFE" on the radio? That is what my radio says. Thanks for the Help!
Post Number: 7865
To reset from SAFE leave SWITCHED ON ...UNDISTURBED for as long as it takes to reset.
The code entry instructions will depend on the exact make and model of radio.
Find yours here
http://www.radio-code.co.uk/code-entry-help.php
A large number of VW radios are made by Blaupunkt and typical instructions are
Blaupunkt 7647236060 - VW Code Entry
Turn on the radio, the display will show 'SAFE'
Press [ TA ] and [ TP ] together until '1000' is displayed.
Input the code using pre-set keys 1-6 and press [ TA ] and [ TP ] to accept.
