Hope you can help me....
Username: Lgarza1313
I recently change the battery of my car and now is asking for a code for the radio to work. its a Chevrolet Aveo Vehicle # KL1TD52654B210739
Hopefully you can help me.
Username: Regrooster
Post Number: 7729
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
