NEED SOME HELP ABOUT THE RIGHT AMP FOR VMAXXES
NEED THE BEST QAULITY AMP FOR AROUND 350 AND UNDER
Username: Lazarus
Keyport, New Jersey
How much power? Watts?
Username: Grmncrsnbr
VA
Post Number: 219
sounds like a question for the amp section
kicker kx550.2 would be great for then, it is about $250 on ebay. The VMAXs are 300 rms I think and even though the amp is rated at 550 watts it will put out something closer to 600 watts.
Oh, and did you get SVC or DVC vmax? You need DVC for this amp.
i have dvc, i was thinking jbl.1200
Username: Suicideshifter
Bristolville, Ohio United States
Post Number: 14
JBL 600.1 or JBL 1200.1, check em out
Why would you get an amp that has twice the power you need? If you are going to get JBL get a 600.2 for two VMAXs. It is a good amp but not as good as kicker, but it also isn't as expensive.
