Anonymous | Pioneer DEH-P7500MP I'm having trouble rewriting the entertainment display. I downloaded the .lkd files off of Pioneers website, burned it, and then the player says "Disc Error, Eject Disc." Their website says to use .lka files, but I can't change their copywrited file extensions. |
kurtiss bird Unregistered guest | You have to download a program called oel 1.1. you have a white display oel and the current progam on pioneers website is for color monitors only. Try this link:http://oel.friscopeepshow.com/. the program you need is in the tools section of the site.-hope this helps. |
