Nissan note radio code
Username: Robejuve
model-mmrcdg
serial number bp53897133604
7645389318 model number.can some one help me ,i lost the code
Username: Robejuve
the serial number isbp538971336304
Username: Regrooster
Post Number: 7608
try code 7709
Username: Tjoyautonigenter
How can u help me to get car radio code software that we cover almost every car radio upto 2010model that we easily decode with serial number and it we get to me in Nigeria.
Thanks:tjoyautonigenter
Help me for this nissan cd.
Serial-CLO44910098802
Post Number: 7762
Temitayo
Posted on Sunday, July 10, 2011 - 02:51 am:
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
Post Number: 7763
Temitayo
Posted on Sunday, July 10, 2011 - 02:44 am:
There is no single software that will do this.
