Need code for blaupunkt car 300 radio
Username: Blond691uk
hi
put new battery in my vauxhall corsa car and now the radio wont work
GM0300X5249482 -7649852320 CAN ANYONE HELP ME PLEASE got a code already and it didnt work
Username: Hay88
PortsmouthUk
Post Number: 3596
Blond691uk
code 5041
Code Entry as Follows:
Turn Off Stereo
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
Need to Register?
Forgot Password?
Enable HTML code in message
