Car radio code
Username: Globalfusion96
i am looking for my car radio code,for my rover 45,i had to have new power cables,and the radio went off.any ideas
Username: Regrooster
Post Number: 7670
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
