Renault Scenic CD Player code
Username: W4lle
Hi,
I'm after a code for my CD player. The guy I got the car from had put in an after market cd player in it. HE hadn't plugged in the radio or anything. I removed it and got a Renault CD player from ebay. I've tried to fit it but the code the guy gave me with doesn't work. Can anyone help please?
Model 22DC278/62B
Ser RN278F40798396
Prod FD0804150798396.
Many Thanks,
Username: Regrooster
Post Number: 7604
Also post the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
Username: W4lle
I'll put everything I have to make sure.
Including the above:
8200057681TU441
8200 057 681 --D
0798396
There is a little box that says U441 Security. Is this what you mean bud?
Post Number: 7610
try code 5 5 5 1
Username: W4lle
Mr Rooster you are a scolar and a gent. The code works great, thank you. The only problem I have now is that it looks like the arial lead isn't attached to the arial on the roof. At least I can play CD's now.
Thank you again.
Very Best Regards,
John
