Radio/cd now code locked...!!!
Username: Daddyoftwins
Blaupunkt Sevilla RD 104 now code locked and showing - - - - How do i now put the correct code in. ? Hope somebody can help. Many thanks.
Username: Hay88
PortsmouthUk
Post Number: 3639
andy
If the display continually shows four bars " - - - - " then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE " Then " 0000 "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press Tuning Up Button " ^ " To Enter
