In wall ideas for non rack mounted equipment ideas?
I want to build my non rack mountable (normal)components into the wall with an open area behind it. Does anybody make a rack or something like that or does anyone have any suggestions?
chad gundlach
I built a nice melamine wood rack on wheels that just rolls in an out of a space----used wood shelving from Home Depot with shelf holes already drilled then put black laminate on it----looks ok ---nice but cheap---i will be moving to a custom made rack soon--
Derek
Building your own would probably be the best way to create a custom rack or you could always call a Cedia certified installer. Also see.
http://www.partsexpress.com/pe/showdetl.cfm?&User_ID=14088186&St=6126&St2=-55154136&St3=54986648&DS_ID=3&Product_ID=117387&DID=7
Hope this helps.
ur page is cool and all its just that i waz lookin 4 my aged type room not lilke a grandma house. im i think u need 2 add to yur pages 4 teenagers u know the colorful type things
Username: Heff
Post Number: 29
AV Rak has a rotating audio/video rack solution--It rotates inside your cabinet or enclosure and mounts quickly with only eight screws.
http://www.avrak.com
Username: Nency
Post Number: 197
hello friend...
Rack-mounted equipment as an option, but I doubt the idea would really take off...
Thanks for....
Username: Avrak
Kelowna, B.C. Canada
Our company Avrak makes three models of 360 degree rotating AV racks, that fit into an entertainment unit, wall enclosure or ithey can stand alone. We also have various sizes as well as custom sizes for every model. You can check out our site http://www.avrak.com/
or email myself Ed Kriger at sales@avrak.com
Username: Davidmartin123
London, ABERDEENSHIRE United Kingdom
You must take help from a professional if you don't have idea to do it yourself.
Need to Register?
Forgot Password?
Enable HTML code in message
