PCMCIA
Username: Slatter
I have a pcmcia card reader and was using a demo program called Memory Card Explorer to read it. It works great but the cost kills me. So i was hoping someone knows of another program like that i can use. The cards can only be read using binary files in a bin file. reading the files is easy once you can get the data off the card.
Need to Register?
Forgot Password?
Enable HTML code in message
