the radio in my ford escape locked itself wen i changed the battery, it is asking for a code to unlock it, it is a 08/2003 model vin jc0yu021031111175, any help would be appreciated,thanx.
Sometimes pressing buttons 6 & 1 together or 6 & 2 will display your Serial Number Otherwise remove the radio from the dashboard and post the SERIAL NUMBER found on a label on the casing
