Unlocking code
Username: Adh11
Hi, could someone please give me the code for a Philips 22RC200/65
TOG964
phapkfx9032532
bought the car and they didn't give me the code
Thanks
Username: Regrooster
Post Number: 7392
try code 5213
This same request was answered yesterday
Username: Adh11
HI,
Thanks for the code I'm just trying to get used to the site. I couldn't find the post i'd done before thats why there are 2.
Was hoping you'd be able to help me, when i connect the radio even after its been disconnected for over 24 hrs it is showing 7ERRORS how do i get this to go so i can try the code you gave me?
thanks for your help
Post Number: 7403
Leave SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself
This may take an hour or more
Username: Adam_2383hotmailcouk
hi need a code for a megane
rnrde 60121275 8200607918t
renrw 333-10 v556
fdo 106420121275
can eny1 help pleas
Post Number: 7414
megane
Posted on Saturday, June 11, 2011 - 01:24 pm:
renrw 333-10 v556
fdo 106420121275
can eny1 help pleas
try code 4479
Username: Bhkate
Hello everyone,
please help me, I need unlock code for GRUNDIG Car200 (D)
90 462 562
GM0200W5988672
Many thanks
Post Number: 7439
Kate
Username: Bhkate
Posted on Monday, June 13, 2011 - 07:14 am:
Hello everyone,
90 462 562
GM0200W5988672
try code 4311
Username: Benjamind
Hi
My Citroen xantia had to have a new battery and now the radio code needs to be put in but I haven't been given one when I bought the car in 2000 ~ can anyone assist in how to rectify this please?
Many thanks
Post Number: 7440
Fleur
Username: Benjamind
Posted on Monday, June 13, 2011 - 10:43 am:
Hi
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Username: Zo123
Hi can i please get the code for a megane cd player please.
MODEL NUMBER: 22DC27762
SECURITY NUMBER: RN277S40622687
PROD NUMBER: FD0704340622687
BARCODE NUMBER: 8200256141TE026
Thank you
Post Number: 7441
zee
Username: Zo123
Posted on Monday, June 13, 2011 - 01:37 pm:
try code 1926
Reminder :..NO MULTIPLE CODE REQUESTS ON THIS FORUM
Single free code for personal use only
This is to prevent abuse by traders+dealers, car radio thieves and other chancers
Sorry if you are one of the honest ones !
Username: Firefightercolmschate
Post Number: 7
hi need a code for my radio for a renault clio 3
with the numbers on the picture
image/jpgUpload
radio 004.jpg (40.4 k)
Username: Adh11
Hi
just to say thanks for the code and info on the radio, so much better driving with some music
thanks Reg
Username: Paul77
Enniskillen, Fermanagh Ireland
renault megane need code for radio
rn277f40407577
8200256141tt655
fdd304050407577
Username: Hay88
PortsmouthUk
Post Number: 3549
Paul77
code 6375
You must hold at the end to store your code.
IF YOU DONT HAVE ¬ KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A¬} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
Username: Marchandx
Hye,
I need a code for a Alfa147 radio
BLAUPUNKT Alfa 937 CD GMBH
BP nr : 7 645 327 316
Fiat nr : 156 053 469 0
815BP532757544756
thanks a lot
Post Number: 7451
marchand.x
Username: Marchandx
Posted on Tuesday, June 14, 2011 - 08:56 am:
Hye,
815BP532757544756
try code 6645
Post Number: 7452
vuurvechter
Post Number: 7
Posted on Monday, June 13, 2011 - 02:56 pm:
try code 7972
