Renault Megane Scenic Code
Username: Mrdead1977
HI, I hope you can help me, ive lost all my paper work for the car radio.
This would be a great help if you could help me
model RENRDW131-10
RNRD 0340195021
PRO NO FD0604360195021
8200300858TB521
Thanks
Username: Regrooster
Post Number: 7336
try code 0425
thank you very much it worked we now have sounds
Username: Fto
Pls help. I have a renault scenic megane. 2004 people carrier (5 seater) and i have been
Strugglling for weeks to get the radio code... Pls any help will be fine
Username: Hay88
PortsmouthUk
Post Number: 3553
Fto
you need to remove the radio.
they are too small holes each side of the radio
use an old metal coat hanger 4 darts or very small screwdriver or long nails.
put into holes about 4-5cms and push outwards sideways
and carefully pull radio forward.
you must do the holes on each side at the same time
Then post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
off of the radio
Username: Fto
thanks im off to work on that now.#
Username: Fto
hello here is the number requested for renault
model number - RENRDW133-10
8200300860TN713
SECURITY - N713
PRODUCTION- FD0404130044333
Username: Hay88
PortsmouthUk
Post Number: 3554
Fto
code 2205
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Then " 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " ¬ " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " ¬ " Until A Beep Is Heard
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
Username: Fto
thx matey........
its aliveeeeeeeeeeeeeeeeeeee
Username: Genti
please help
model nr; 22DC279/62P
T0R304
RN279F10286435
prod. nr:FD0301330286435
7700434425TR304
7700 434 425
renault scenic
2002
thank you in advance
Post Number: 7495
jona
Username: Genti
Posted on Thursday, June 16, 2011 - 04:06 pm:
please help
T0R304
RN279F10286435
7700434425TR304
7700 434 425
renault scenic
2002
try code 8693
Username: Genti
Thank you mate!!!!!!!!!!!!!!!!!!
My scenic is again noisy!!!!!!!
I apologize for duplicating post.
