Good USB Head Units??
Username: Fernan2_rd
SantiagoRep. Dom.
what brand of head unit you choose (2011 models)?:
KENWOOD
JVC
PIONEER
ECLIPSE
i listen rap, r&b, techno and reggae music, i need the best HU for this
Username: Kaerfpl
Spencerport, NY USA
Post Number: 1034
With the new models of 2011 on your list, I personally would go with Kenwood, but that is just my opinion.
What is your price range?
SantiagoRep. Dom.
i put max u$170 in a head unit no more
SantiagoRep. Dom.
i heard sony new models are great, is this true???
Username: Joe1234
Post Number: 56
JVC and Sony are entry level and the price advantage is not that great. You need to find out the maximum memory size and number of audio formats and file systems that the HU supports, I can tell you that Pioneer has superb format compatibility. Kenwood is another one to look at. Alpine (excellent as it is) for example has refused playing some very big files that Pioneer handled with ease.
Username: Kaerfpl
Spencerport, NY USA
Post Number: 1036
Sony is something I would never recommend in Car Audio. It's just simply not worth the money.
As joe durkham stated above, JVC is more of an entry level brand, however some of their higher end Decks ($500 plus range) are superb.
As far as you price range goes, here are a few options you can look into:
Pioneer DEH-P8300UB:
http://www.sonicelectronix.com/item_31077_Pioneer-DEH-P8300UB.html
Kenwood KDC-448U:
http://www.sonicelectronix.com/item_33460_Kenwood-KDC-448U.html
Alpine CDA-105:
http://www.sonicelectronix.com/item_18875_Alpine-CDA-105.html
Alpine CDE-122:
http://www.sonicelectronix.com/item_34355_Alpine-CDE-122.html
Clarion CZ501:
http://www.sonicelectronix.com/item_35579_Clarion-CZ501.html
