Gold Member Username: Regrooster
Post Number: 7432 Registered: Aug-08
Posted on Ask the seller ! If it is a fairly new radio then it may be VIN coded which means it has to be linked to the vehicle it is to be fitted into. Main Dealer or Radio Decoding Service only If it also requires a code then it will not be available for free or cheap from anywhere on the Internet
