Can anyone help? I've just bought a Merc E320 estates X reg. The radio didn't work. I contacted Mercedes and they gave me there code, this didn't work. The radio must have been changed. The s/no of the radio is AL291010680423. Can anyone tell me how to get the code?
Can you help me with mine? Wanted to weld the silencer and had to remove the battery. Radio has never worked since! Car Mercedes Benz E320 97 model VIN: WDBJF65F0WA520851
Post Number: 1 Registered: Jun-11 Posted on Sunday, June 12, 2011 - 12:47 pm: Can you help me with mine? Wanted to weld the silencer and had to remove the battery. Radio has never worked since! Car Mercedes Benz E320 97 model VIN: WDBJF65F0WA520851
Help will be greatly appreciated... Regards ============================== The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Yes.....if you quote the VIN to your Merc Dealer he can look up a code on the Mercedes Database ......but it will normally involve paying a fee and may not be the correct code if the radio has been changed..( This Merc database is not commercially available as computer software )
If you want to see if we can provide a code for free on this forum then you are going to have to quote the details on the radio so that the code can be calculated. (providing there is an available calculator) . .
