Gold Member Username: Regrooster
Post Number: 7415 Registered: Aug-08
Posted on Sorry......this is insufficient information The radio has to be removed from the dashboard Then post the 14 character SERIAL NUMBER beginning with RN* * * * * * * * * * * * found stamped in the metal casing. Also post the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode |
