Need code for radiosat 4000
Username: Geert25
Hi,
i need to enter a code to unlock my radio
info:
philips 22dc451/62e
7700433073 i825
rn451fw2033393
thanks in advance
Geert
Username: Geert25
i see it's in the wrong section, so if an admin can move it, it would be great
srr for this.
Username: Hay88
PortsmouthUk
Post Number: 3433
Geert25
code 8319
Username: Diego22
Guadalajara, Jalisco Mexico
I need the code for my Renault Kangoo
I wish you could help me
Te info I have is:
RNRDBZ80017121
RENRDW300-05
FD058170017121
8200 585 305 --B
8200585305T
P433-SECURITY
THANKS IN ADVANCE
Username: Hay88
PortsmouthUk
Post Number: 3546
Diego22
code 0590
You must hold at the end to store your code.
IF YOU DONT HAVE ¬ KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A¬} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store
