Blaupunkt Code
Username: Xcitnu
Hi, i have a holden vectra which comes stock with a blaupunkt cd player. i do not have the security code
the numbers on my cd player are:
239130787236
92 057 951
Thank you very much !!
Username: Regrooster
Post Number: 7361
try code 9143
Username: Zedd1
Hello
I've purchased for My wife's alfa 147 a used cd/mp3 player but the seller did not Have the security code.
I only Have the following infos:
VIN: MAL5601K5630
815 BP 669874987778
Thanks
Username: Hay88
PortsmouthUk
Post Number: 3531
Zedd1
try code 5514 or if you can enter higher than a six try code 3594
Username: Zedd1
Thanks a lot hay88 i'll try as soon as my wife come back home !!
i'll let you know..
thanks again
Username: Xcitnu
Thank you so much !!!!
It worked :D
Great forum and very helpful users
Once again thank you very much
Username: Zedd1
Thank you very much hay88 ! your code works !!
Greattttt !!
