New member Username: Xcitnu
Post Number: 1 Registered: Jun-11
Posted on Hi, i have a holden vectra which comes stock with a blaupunkt cd player. i do not have the security code the numbers on my cd player are: 239130787236 92 057 951 Thank you very much !! |
Gold Member Username: Regrooster
Post Number: 7361 Registered: Aug-08
Posted on try code 9143 |
New member Username: Zedd1
Posted on Hello I've purchased for My wife's alfa 147 a used cd/mp3 player but the seller did not Have the security code. I only Have the following infos: VIN: MAL5601K5630 815 BP 669874987778 Thanks |
Gold Member Username: Hay88
PortsmouthUk
Post Number: 3531 Registered: Mar-10
Posted on Zedd1 try code 5514 or if you can enter higher than a six try code 3594 |
Post Number: 2 Registered: Jun-11
Posted on Thanks a lot hay88 i'll try as soon as my wife come back home !! i'll let you know.. thanks again |
Posted on Thank you so much !!!! It worked :D Great forum and very helpful users Once again thank you very much |
Post Number: 3 Registered: Jun-11
Posted on Thank you very much hay88 ! your code works !! Greattttt !! |
