Lost code for Renault Megane
Username: Musicistas
I hope you can help me!! You are great!!
Model No: 22DC277/62
Prod No: FD0002470059486
RN277F20059486
TOZ388
8200256141TZ388
Username: Regrooster
Post Number: 7340
try code 0678
thank you!! I'll donate to you within next week!! You are great!!
Username: Malo_stapalo
Bitola, Macedonia
can anyone HELP me...i lost my code for my radio...i have megane scenic but i dont know where to find Model No: & Prod No:
HELP !!!
Username: Tarajanes
Tonbridge, Kent
Think you need to remove the stereo,and details should be underneath..but dont quote me on that...
Post Number: 7351
Malo_Stapalo
Bitola, Macedonia
Posted on Monday, June 06, 2011 - 09:39 am:
HELP !!!
The radio has to be removed from the dashboard
Then post the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also post the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
