Code for my new cd radio player. PLS
Username: 306nreg
Hi:
I need your help guys .. just bought second hand cd radio player clarion for my old 306 n reg.. but it ask me for code
Model: PU-2294A ©
Serial: CL0401Z556043
Thanks
Username: Regrooster
Post Number: 7352
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
