My brother wants to put a sub in has S-10 regular cab truck. What would work best and fit behind the seat. I though about some 6x9's or a 8". thanks for any suggestions
Go with either an 8" kicker L7 or an 8" JL Audio W7. Both will hit nice and hard for ya, depends on what you are looking for, SQ or SPL. I'm prety sure JL makes the W7 in 8" anyways...
any low watt 10 should just about fit, friend has a pioneer 10 in his we made the box for it and it in a small enclosure hit hard as hell and sounded clean, i assume its the vehicles cabin gain but it sonded real nice with just 180 watts, and ya im runnin 3 shiva 12's off a jbl 1200.1 amp with an alpine 9831 head unit so i know what a nice sound system sounds like
Any 10" that is optimized for a small enclosure should work well. Adire Audio Brahmas would be fantastic in there, excellent SQ and SPL there. Only needs about a .6 cubic foot enclosure per sub for optimum performance. It depends on your budget, though.
