Freq Tuning
Username: Jtb
Post Number: 19
I was wondering how you tune a box to 30hz or 40z ect. Is it only the box dimensions that affect the frequency it is tuned at, or is it something else? Can anybody tell me or direct me to a website? Thanks.
Username: Grmncrsnbr
VA
Post Number: 174
if you mean a ported box then you change the tuning by changing the diameter and length of the port tube
Username: Jtb
Post Number: 20
so if I put an IDQ twelve in a ported 18x12 slot what would the freq be?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 3851
the tuned frequency is determined by the box's net volume, and the diameter and length of the port(s)
here:
http://www.diysubwoofers.org/prt/
www.bcae1.com has calculators for ported box design, too.
scan the right menu for the basic calculators topic.
karl tanner
i have two 300 watt max subwoofers and my amp is
1000 watts max would it work
Username: Jayj
Louisiana USA
Post Number: 331
Karl it depends on the RMS rating not the MAX. what is the RMS on the products. What are the name and models and I'll look it up and help you out.
