LOST MY STEREO CODE
Username: Suzzi1234
LOST MY CODE WHEN I TOOK MY BATTERY POWER LEAD OF MY RENAULT CAN YOU HELP THANKS
model no: 22DC258/62P
TOW907
RN258F20052629
PROD NO: FD0102230052629
Username: Hay88
PortsmouthUk
Post Number: 3507
Suzzi1234
code 3025
You must hold at the end to store your code.
IF YOU DONT HAVE A KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {AA} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ A] button then rotate the thumb wheel for the correct first digit
Press the [ A] button then rotate the thumb wheel for the correct second digit
Press the [ A] button then rotate the thumb wheel for the correct third digit
Press the [ A] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ A] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
