Silver Member Username: Iamduff_87Michigan America! Post Number: 111 Registered: May-04 | OK i probably will not get a set of compononts yet but i was wondering where I would install the tweeters in my car. I have a Nissan Maxima 93 with 6.5" mounts 3/4 way down the front door. where would i mount the tweeters and would i need a new mount for the woofer also? i was looking into Infinity Kappa series 6.5" compononts. and would a RF 60ix ... 60x2@2 amp work good with these??? thanks for the help. |
Silver Member Username: MattlBolingbrook, Illinois USA Post Number: 155 Registered: Jun-04 | In the dash firing up is my personal preference, then pillar, then door. Kappa Perfects require 100W RMS, while the plain Kappas require 90W, both at 4-ohms. The 60ix is 30Wx2 at 4-ohms.. far less than desireable. -Matt |
Silver Member Username: Iamduff_87Michigan America! Post Number: 116 Registered: May-04 | is there any way to run the speakers at 2ohms since I could give them 60wX2@2ohms? The amp is bridgable and 2ohm capable. |
Silver Member Username: MattlBolingbrook, Illinois USA Post Number: 160 Registered: Jun-04 | That's not suitable in this case. To present them as a 2-ohm load, you'd need to wire them in parallel, which would be 1 channel and still underpowered. -Matt |
