I've recently got a JL 250-1 amp and I was wondering what JL sub would work best with my amp. I want a 10" so would the 10W0 be best or should I get a better one. I dont listen to any rap or hip hop music either, if that helps at all, I dont know. Any help would be great. Thanks
Yeah that JL amp is perfect for a JLW0. Thats if the 250 is RMS power. Glasswolf said in another post that the W0 sounds the best with 100 to 150W. Since you dont listen to rap a 10" JL is perfect.
