Mixing Speaker Brands....?
ChewBacca
Is it ok to mix different brands of speakers? Like i have some eclipse 6"x9" and i also have some diamond audio 4" components. Will it matter? Thanks -ChewBacca
Username: Jamtochristian
Williamsport, Pennsylvania USA of course!
Post Number: 111
Chewbacca, its electronically possible to mix them, its just watts running down a wire, and the watts don't particularly care what the brand is... so yes its possible. As for sound stage, and the quality of sound... now that can depend. I'm guessing you have A set of Diamond audio components in the front, and a set of 6x9's in the back deck.
Username: Mattl
Bolingbrook, Illinois USA
Post Number: 172
It's generally not recommended because the timings and reproductions may be off between manufacturers and even productlines.
If you're planning upgrades, stick with the manufacturer you think sounds better of your current set and build upon them.
-Matt
