Bronze Member Username: Chris_ballerPenetanguishene, Ontario Canada Post Number: 27 Registered: Jun-04 | are clarion amplifiers any good? What about legacy subs are they better than pyle subs, brand name wise? |
Silver Member Username: JayjPost Number: 186 Registered: May-04 | 1 Clarion amps are OK. Not what I would pick but OK. 2 Legacy AND Pyle are both JUNK. 3 Try something a little BETTER. |
Bronze Member Username: Chris_ballerPenetanguishene, Ontario Canada Post Number: 28 Registered: Jun-04 | what about those lightning made my RF |
Silver Member Username: Davids2004Houston, TX USA Post Number: 203 Registered: Jun-04 | If you search around you can find good brand name stuff for about the same price or a little more then the cheap stuff. How much are you looking to spend on subs. do you want one or two subs. |
Bronze Member Username: Chris_ballerPenetanguishene, Ontario Canada Post Number: 29 Registered: Jun-04 | can you reccomend something that has good sound quality and high bass for less than say $500 for 2 subs prefferably 12" and maybe a good amp to power those subs. |
Silver Member Username: JayjPost Number: 188 Registered: May-04 | Oh yeah. Go for 2 12 Cerwin Vega V-maxx. And a JBL600.1 amp. That is good sound. Heres the sites that I've found with the best prices. Get the subs here. http://www.acaraudio.com/product_info.php?manufacturers_id=52&products_id=1257 Get the amp here. http://www.cardomain.com/item/JBLBP6001 |
Silver Member Username: JayjPost Number: 189 Registered: May-04 | Oh yeah. Go for 2 12 Cerwin Vega V-maxx. And a JBL600.1 amp. That is good sound. Heres the sites that I've found with the best prices. Get the subs here. http://www.acaraudio.com/product_info.php?manufacturers_id=52&products_id=1257 Get the amp here. http://www.cardomain.com/item/JBLBP6001 |
Bronze Member Username: Chris_ballerPenetanguishene, Ontario Canada Post Number: 30 Registered: Jun-04 | thanx a lot man, much aprreciated. |
Silver Member Username: JayjPost Number: 190 Registered: May-04 | No problem. You will be VERY happy with that set up. |
Silver Member Username: JayjPost Number: 191 Registered: May-04 | No problem. You will be VERY happy with that set up. |
Bronze Member Username: Chris_ballerPenetanguishene, Ontario Canada Post Number: 31 Registered: Jun-04 | with that amp could i power my speakers aswell, i have 2 6" blaupunkt fronts and 2 6x9" pioneers in the back |
Silver Member Username: Davids2004Houston, TX USA Post Number: 206 Registered: Jun-04 | Ok here you go. DD1012-2 129.00 a piece (www.ddaudio.com) Hifonics NX600 150.00 (http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5706857428&rd= 1&ssPageName=WDVW) This will cost you a little more but more suited for SPL. |
Silver Member Username: JayjPost Number: 194 Registered: May-04 | No that amp is made for subs ONLY. I would recommend a good 4 channel amp for them. JBL has some nice 4 channel amps look at them. |
Silver Member Username: JayjPost Number: 195 Registered: May-04 | Chris don't buy that Hifonics piece of crap stick with the JBL. I have seen a lot of those hifonics amp fail very quickly. |
Anonymous2 Unregistered guest | You can go f*** yourself JayJ, Hifonics makes good amps for the money that are on the same level as JBL. Maybe the ones you've seen fail were owned and operated by complete dipshi*s such as yourself. |
