Unlocking code Volkswagen Jetta Radio
Username: Abnabat
Harbor City, CA United States
Hi,
Could someone please give me the code for following car radio?
RCD 300
Delphi Radio
VWZ4Z7G6289449
89FFXVR372430740
Would really appreciate it.
Thanks
Username: Regrooster
Post Number: 7442
Sorry....Main V W Dealer or Radio Decoding Service only for this code
It will not be available for free or cheap from anywhere on the Internet
Username: Abnabat
Hi,
I actually managed to get the code from Radio-code.com for 24 dollars and this was the same code as I had before. The code still does not work. Eventhough 2 sources have confirmed this is the code.
could this be wiring problems?
Thanks
Amin
Post Number: 7458
It will usually be due to the radio being recoded to a completely different number
The only solution now is to take it into a Radio Decoding Service (such as a local Car Radio/Audio store) where they will connect a laptop to read the actual code inside the radio's memory chip (EEPROM)
