Clarion pu2294a code wanted
Username: Ivandeschacht
Hi,
Just bought a second hand clarion PU-2294a radio/cd for my
peugeot 206, but there isn't any code joined.
Can anyone help me resolve this problem please?????
Serial nr : CL040140913239C
Thanks in advance.
regards
Username: Regrooster
Post Number: 7159
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
