Hi all, I just bought a second hand Nissan for my mum from a car dealer and i need security code for the radio of the following details: S/N BP2770R4516303 Model 7642770318
Hi Guys, I bought opel Vectra 1996 and the seller didnt give me the code of the Radio. so i dont use it since 5 months.. looking for: Blaupunkt car 300 d GM:90383441 No. 90532620
Posted on Friday, May 20, 2011 - 09:33 am: Hi Guys, I bought opel Vectra 1996 and the seller didnt give me the code of the Radio. so i dont use it since 5 months.. looking for: Blaupunkt car 300 d GM:90383441 No. 90532620 ========================
Duplicate post ...Already answered
Please do NOT post the SAME request in more than ONE thread.
Code Entry as Follows: Switch On Ignition (No Need To Start Engine) Press & Hold Preset " AS " and Switch Radio On - Display Shows " SAFE " And Then Shows " 10 - - - - " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press & Hold Preset " AS " Until the Unit Beeps
Hi, I have a 2003 Astra with a Blaupunkt 520. I had to get the alternator replaced and now the radio is asking for a code. I've put in a couple of codes but i'm down to SAFE 7 and I can't seem to even get it to take another code at all.
I'd appreciate if someone can help me get it to accept a code and I'd very much appreciate a code that might work!
Post Number: 1 Registered: Jun-11 Posted on Sunday, June 05, 2011 - 07:03 am: Hi, I have a 2003 Astra with a Blaupunkt 520. I had to get the alternator replaced and now the radio is asking for a code. I've put in a couple of codes but i'm down to SAFE 7 and I can't seem to even get it to take another code at all.
I'd appreciate if someone can help me get it to accept a code and I'd very much appreciate a code that might work! =====================================
It looks as though you are using the wrong code.
Post the code you are using and also post the 14 character SERIAL NUMBER beginning GM or BP and found stamped in the metal casing and also the number beginning 7+++ +++ +++
