Think my amp took a crap!!!
Username: Tcrowden
Ocean springs, Ms.
Post Number: 72
Turned the radio on and it sounded like thunder coming from the subs,even with the volume all the way down and the rca's unpluged.
Username: Stevokentucky
Frankfort, Ky Us
There is definately something wrong somewhere between the amplifier input and your radio. Go to your amp and turn the gain way the frig down lol and check your RCA cables front to back. If there is nothing wrong with your RCA cables then its likely that there is a problem with the preamp section of the amplifier.
Username: Tcrowden
Ocean springs, Ms.
Post Number: 73
It's something inside the amp.It's in the shop,should hear something this week.
