Code for clarion
Username: Madmechanic
hi to all you good people im looking for a code for a peaugot radio i believe its a clarion model pu-2325a(b) serial cl0410y0113298 any help would be greatfully appreciated as it would keep wife off my case thanks in advance
Username: Regrooster
Post Number: 7146
the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
so if i get the barcode from unit i can get a code ?
