Please help with GM opel grundig car 200 (D)
Username: Lisaee2001
I NEED SOME HELP WITH A UNIT THAT CAME WITH A USED OPEL CORSA I JUST BOUGHT, THE CODE SEEMS TO HAVE BEEN LOST.
GRUNDIG
no: 90462562
type: car 200 (D)
w8n
GM0200T3093581
THANKS!
Username: Hay88
PortsmouthUk
Post Number: 3475
Lisaee2001
try code 2687
Code Entry as Follows:
Switch On Ignition (No Need To Start Engine)
Turn Off Stereo
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
