Radio code renault megane 52 plate fidji?
Username: Systemline
anybody no the radio code for a renault megane 52 plate fidji?
r n 279f20229537
7700434423
7700434423td727
Thanks Mel
Username: Bogege
BG
Post Number: 274
Systemline try code 0084
Username: Malcolm51
LondonEngland
I recently changed the battery on my sons 2002 renault megane and now the radio is asking for a code. Can anyone help?
Model No 22DC259/62T
TOT117
RN259F23643318
Product No FD0502193643318
Username: Hay88
PortsmouthUk
Post Number: 3461
Malcolm51
code 6865
You must hold at the end to store your code.
IF YOU DONT HAVE A KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {AA} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ A] button then rotate the thumb wheel for the correct first digit
Press the [ A] button then rotate the thumb wheel for the correct second digit
Press the [ A] button then rotate the thumb wheel for the correct third digit
Press the [ A] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ A] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
Username: Malcolm51
LondonEngland
hay 88
Many thanks the code worked
malcolm51
